11-25-2016,
I have air leaking around the bolts in the picture, What can i do to stop the air leak?[attachment=2238][attachment=2239]
(11-25-2016 )in2trux Wrote: [ -> ]Those plugs look really cruddy. See if you can buy a couple of new plugs, dump all the air and clean the threads in the tank thoroughly and reseal with teflon tape. Air tanks rust from the inside out.What's is the best way to clean tank???? Also do you think the plugs are dealer item
(11-25-2016 )Brock Wrote: [ -> ]Go to any heavy truck part store that sells fittings and you can buy the plugs. Teflon tape and your good.
Hell i wouldn't even bother changing the plug's but I'm a cheap bastard!
(11-26-2016 )Hammerhead Wrote: [ -> ]That what i am going to do, just clean them and re-Teflon them... Just one more question...What is a good cleaner for air systems???(11-25-2016 )Brock Wrote: [ -> ]Go to any heavy truck part store that sells fittings and you can buy the plugs. Teflon tape and your good.
Me too. I'd pull them, wire brush clean them, re-Teflon tape them, and shove them back in.
Personally I'd be more worried about those POS push in synflex line connectors. Those things are about as effective as screen doors on submarines when it gets cold! I'd like to kick the SOB that came up with that dumb idea in the gonads. Once for every single one produced since he developed that brain fart!
I'd tell you how I really feel, but that's why I have no friends, so I'm trying to play nice...is it working?
