HA! seriously....Yeah I saw that the manual on quickserve had said that too. "don't remove barrels from the head" I did the same, put it in the vise, slapped on the 1& 3/8 (A awful long wrench mind you) grabbed ahold and holy crap it wouldn't budge. Added a long breaker bar, and cohersed it off. But, I can't help ya on the torque. Wish I could, but mine was just an exploratory tear down on the old 3 cylinder head, curiosity more then anything.
i have the spec here somewhere. its 80ftlbs plus 60ish degrees i think but i will have to verify.
the kit with the plungers, tappets, and barrels fits both the 3 and 2 cyl pump. i dont know why cummins has such a hard time with this!! I still see 3 cyl pumps fail with updated parts though, so fair warning on that.
Unilevers: thanks for the info. Glad to know the kit is compatible. I am going to do some searching and see what I can find for a gear pump. Maybe some online parts house will still have a new one laying around......hey stranger things have happened, right?
(04-15-2017 )Unilevers Wrote: [ -> ]i have the spec here somewhere. its 80ftlbs plus 60ish degrees i think but i will have to verify.
If the ceramic plungers are changed, then what is the next failure on the three cyl pump?
Thanks for the torque info, when you locate it I'd appreciate if you would email the procedure to me. CWC Edmonton couldn't provide one, go figure.
I found video at quickserve saying 60ft lbs and 60 degrees.
Here is link how to inspect fuel pump head:
https://www.dropbox.com/s/r64xtf1je9hta3...n.mp4?dl=0
Here is link to video installing barrells with torque specs:
https://www.dropbox.com/s/n9dqxkb70laxc4...l.mp4?dl=0
Also barrels and plungers for 2250 and 2350 have different part number and they cannot be mixed. Installing incorrect barrels and plungers will result excess fuel in the oil
attachment=2753]
They have different part numbers:
For CM2250 Fuel Pump Barrel and Plunger Repair Kit, Part Number 4327258;
Retainer, Spring 2872626
Seal, O-Ring 3867651
Barrel and Plunger 4307402
Spring, Compression 4928605
Washer, Sealing 4954944
For CM2350 Fuel Pump Barrel and Plunger Repair Kit , Part Number
5406130;
Seal, O-Ring 3330538
Barrel and Plunger 2897343
Simon999: excellent work!! Much appreciated!
