(12-16-2016 )Hammerhead Wrote: [ -> ] (12-15-2016 )scottydogtruck Wrote: [ -> ]Did you perform the DPF Restriction Test per Ins1te? I had mine cleaned at a Cummins Shop, nothing unusual from the outside, but they did the test and it FAILED!!....so I had the DPF replaced.....costly.
Before you spend any more $$$...and wasted time on small problems, do the restriction test, I believe you have a stuffed-up DPF, from some internal engine problem.
Jeez! You'd think that part of the Cleaning Process would be a flow test BEFORE they returned the damn thing! No sense returning an internally plugged freshly cleansed DPF to a customer???
sorry, I know my post is of zero help value, just a rant at the nonsense of returning a "cleaned" DPF that is still plugged...
I had Cummins in San Antonio do just that...after cleaning the unit, they returned it to my system, new gaskets installed, and did the test.....FAILED!!! So...I had them replace the DPF..at a cost of $1,700 for the unit, and redid the test.....VOILA!! Passes.......total cost out of my pocket...$2,477.19.
I called a freightliner dealer and was quoted $800 and some change for a remanned DPF filter. A lot cheaper than a new one. Any thoughts on a remanned DPF versus new?
(12-17-2016 )RSCTRANS Wrote: [ -> ]I called a freightliner dealer and was quoted $800 and some change for a remanned DPF filter. A lot cheaper than a new one. Any thoughts on a remanned DPF versus new?
DPF can not be remanned. New or used.
Would you pay $800 for used unknown condition? Remember there is no warranty on used parts policy.
I have never met anyone who had a reman DOC filter that worked well, but I have had a couple people tell me that reman DPF filter was working ok for them but not great. Problem is, that most of the time, people who get reman DPF already have other engine issues to go with it. So who knows for sure.
I just want to put this out there and lets keep an eye on this ECM update CL10038.46. Since my update is when I've been getting tones of DPF CODES. Now I'm no mechanic and I've been reading and search as much as I can about the DPF system.
I understand at some point i'll get codes and I may even have some that will pop up as soon as I hit the road. I got these code on Sunday last week 2754 intake pressure filter, 3375 dpf frequent regen, 3582 scr conversion efficiency. Along with these code I had 2 more that came and went away while driving.
Brought it to shop mechanic used insite, fixed my clutch pedal and forced a regen. Codes gone. He said that there’s nothing wrong with my dpf system. A few months before that I got active 3225 afterthreatment purge air actuator not responding or out of adjustment, active 1694 NOx sensor (that was just changed) aftertreatment particulate filter differential pressure (inactive).
After clearing codes they’ve never come back.
I’m new at this and dealing with my own issues. I may be wrong but I thought I’d post FOOD FOR THOUGHT.
If I do this right here is what the DPF look like when we took it out last week. It was last baked in September
Looks like you have some cracking going on....internally. The soot lines and the two small soot patches are signs that the soot is being blocked due to the flow being interrupted by the cracking.
Also, who resealed the DOC? Look at the gasket...it looks like whoever did it didn't seal it properly...
IMHO...
