02-02-2017,
(02-02-2017 )Unilevers Wrote: [ -> ]its getting closer! do i get to see it soon?
Hopefully just a few more days!
(02-02-2017 )RPM1 Wrote: [ -> ](02-01-2017 )Rig Wrench Wrote: [ -> ]Same way you would the combustion chamber in a gas cylinder head. Just now you do it to the piston
https://m.youtube.com/watch?v=yqAr4DUqEt4
i know how i do it , i was just curious how u did it . so basically your just matching the cc of each bowl . are u checking centerl ine distance of wrist pin to top of piston , or bowl configuration as all that will affect compression ratio ,also changing top of piston hight changes the squish area between the head , also even though the cc of the bowl is off one piston to the other as a quick check u need to keep in mind bowl depth and bowl diameter .
of course the only real way to know is to put the pistons on a cmm and have them checked
and go from there , and maybe u end up having to re machine the bowl and top to get everything equal in relation to wrist pin center line then u would have uniformity , just my 2 cents if was my engine and i wanted to be nats on
ps the top of piston to top of first compression ring will affect compression a tad
(02-02-2017 )Rig Wrench Wrote: [ -> ](02-02-2017 )RPM1 Wrote: [ -> ](02-01-2017 )Rig Wrench Wrote: [ -> ]Same way you would the combustion chamber in a gas cylinder head. Just now you do it to the piston
I check volume before and after. The actual cutting is done through a cad type program on a lathe type machine. I don't physically grind it out myself. The bowls from a low (16:1) compression engine are scanned, saved, then re applied to the new piston. An exact match then. Why wouldn't you want it nats on???
(01-31-2017 )RPM1 Wrote: [ -> ](01-30-2017 )Brock Wrote: [ -> ]Front structure is off, deck is getting cleaned off. Got all my parts in.... went with the federal mogul FP diesel cylinder kits, cat everything else including head and injectors.
Here's a pic of the new piston
Went with the FP diesel cause they are new rather than reman and have a ceramic coating which I really like.
Cylinders going in today!
there not ceramic coated , there phosphate and grafal coated , reduses friction , if memory serves me right mahal has been a oem pistion manufacture for cat cummins jd an others , that is there monanotherm one piece forged steel pistion , why they ever tryed a 2 piece pistion is beyond me .
(02-04-2017 )Brock Wrote: [ -> ](01-31-2017 )RPM1 Wrote: [ -> ](01-30-2017 )Brock Wrote: [ -> ]Front structure is off, deck is getting cleaned off. Got all my parts in.... went with the federal mogul FP diesel cylinder kits, cat everything else including head and injectors.
My understanding is the entire piston is coated like you stated but mine were ordered with a optional ceramic coating which i believe is the off color part you see on the skirt.
(02-05-2017 )Brock Wrote: [ -> ]Coming together nicely. Removing all the mandated junk off her, boy is there a lot of extra useless crap!
Mechanic wants to remove the intake pre cooler, says it's useless. Not sure how I feel about that one yet.
