(03-02-2017 )Brock Wrote: [ -> ]Did you get the normal ones or Thier heavy haul ones!
I cant recall them saying anything about being heavy haul. They were listed as RK-RP4037... The bushing design sort of scared me when I first installed them because i could pivot the shock with my hand when installed and tight but they have held up great for over 150k hard miles which are a mixture of city/highway in addition to the quarry's and sand pits and occasional job site.
(03-02-2017 )Pete379 Wrote: [ -> ] (03-02-2017 )Brock Wrote: [ -> ]Did you get the normal ones or Thier heavy haul ones!
Oh ya, that's kinda like the Atro polyurethane bushings that are designed to rotate freely.
(03-02-2017 )hhow55 Wrote: [ -> ]You may want to check out Hendrickson shock's. I put them on my western star, and I have to admit I have never had a better ride in the 30 year's I have been driving.
Do you know where I can buy these Hendrickson shocks
(03-03-2017 )GhumanTruckService Wrote: [ -> ] (03-02-2017 )hhow55 Wrote: [ -> ]You may want to check out Hendrickson shock's. I put them on my western star, and I have to admit I have never had a better ride in the 30 year's I have been driving.
Yes Sir,
I bought mine at Beaumont Freightliner Dealer, you should be able to find them at any western star dealer. Also checkout Hendrickson-intl.com
(03-02-2017 )jimeneztrans84 Wrote: [ -> ] (03-02-2017 )Waterloo Wrote: [ -> ]I priced out those Road Kings, they were not cheap, I want to say around $2000+ for the front and rears... If I was driving a desert racer that is one thing... To expensive for my wallet, even if they can be rebuilt.
I'm using the Gabriel Adjustable on my drives, I like them, have them set at medium stiffness as I rarely haul anything heavy. https://amzn.to/2VFXSCl
Monroe on the front. https://amzn.to/2Y5n56K
Saved quite a bit by purchasing on line.
Will these fit on a 2011 kw t660? Looking for front drive shocks and rears.
You will have to go to Monroe and Gabriel website to check for your particular application. I have a ProStar and there is not much out there for us guys...
