Hi Guys,
I've watched rawze (and others) running an overhead on the earlier DOHC ISX, but wondering if there was a similar video out for running it on a later model SOHC? (Cm2250/2350)
Cheers
(03-06-2017 )Liquidforce Wrote: [ -> ]Hi Guys,
Cheers
No difference. The 2250, 2350, and Rawze's instructional video of an 871...it's all the same, other than that you don't have to adjust the injector preload on a single cam.
So simply ignore the injector part, and follow the valve cam portion of the procedure.
And instead of removing the oil filler to bar it over, you just pop out the rubber plug in the gear cover.
(03-06-2017 )Signature620 Wrote: [ -> ]And instead of removing the oil filler to bar it over, you just pop out the rubber plug in the gear cover.
Thanks, I keep forgetting to tell people that difference...
