SOHC ISX overhead |
03-06-2017, (Subject: SOHC ISX overhead ) Post: #1 | |||
SOHC ISX overhead Hi Guys, I've watched rawze (and others) running an overhead on the earlier DOHC ISX, but wondering if there was a similar video out for running it on a later model SOHC? (Cm2250/2350) Cheers | |||
03-06-2017, (Subject: SOHC ISX overhead ) Post: #2 | |||
RE: SOHC ISX overhead (03-06-2017 )Liquidforce Wrote: Hi Guys, No difference. The 2250, 2350, and Rawze's instructional video of an 871...it's all the same, other than that you don't have to adjust the injector preload on a single cam. So simply ignore the injector part, and follow the valve cam portion of the procedure. User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..." | |||
03-06-2017, (Subject: SOHC ISX overhead ) Post: #3 | |||
RE: SOHC ISX overhead And instead of removing the oil filler to bar it over, you just pop out the rubber plug in the gear cover. | |||
03-06-2017, (Subject: SOHC ISX overhead ) Post: #4 | |||
RE: SOHC ISX overhead (03-06-2017 )Signature620 Wrote: And instead of removing the oil filler to bar it over, you just pop out the rubber plug in the gear cover.Thanks, I keep forgetting to tell people that difference... User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..." | |||
