05-12-2017,
So many times I was in the situation that I need a part for my 2010 Peterbilt 387 and the local dealership doesn't have it or they just charge a lot more than this part actually values. So I decided to plan ahead and order it online. The problem is that the stealerships will not give the part number out because that's the policy of the company or they will say "class pays" yeah pays for sure somebody else only not me. I had a hard time shopping the parts from dealership so for everybody else who wanna save some money I'll start a thread with the OEM Part Numbers for Peterbilt&Kenworth Trucks
2010 PETERBILT 387
SYMPTOM - HARD CLUTCH PEDAL WON'T RETURN AND DOESN'T ENGAGE THE CRUISE CONTROL SWITCH
Part Changed - Clutch Cable Assy 06-01521-0965 (the OEM part came with a too short U-bolt, had to custom made a new one with longer threads bought a zinc round rod from ACE hardware, bent it to the needed dimensions and made threads by myself)
SYMPTOM - FRONT SPRINGS CLUNKING NOISE WHEN TURNING WHEEL
Part Changed - Horton Shackle 994610 (it may differs from yours, take the measurements first, distance and diameter of the pins then go to Horton website and chose which one fits)
SYMPTOM - HARD START
Part Changed - Starter Delco 8200308 39mt
SYMPTOM - LEAKING AIR BAG
Part Changed - Air Spring Contitech AS9069 64274/1R12-069/8312 (it may differs from yours)
SYMPTOM - HARD SPOTS WHEN TURNING WHEELS
Part Changed - Steer Gear Box TAS 65166R by Federal Mogul - TRW
and Pitman-Arm 10-02940
Will keep updating as new repairs will come
2010 PETERBILT 387
