07-15-2017,
07-15-2017,
Well if its like a w900 its a bitch.... pull off the lower cover on the steering wheel and look under all the sh#t thats in the way and you can see (sort of) where it go's..theres a place for the spring on the pedal and it hook's on a deal up under there.. its a pita's just make sure you look at what needs to be removed so you can see where it go's
and make sure you got the spring snug. it a cheep fix just a pita.
