Clutch pedal |
07-15-2017, (Subject: Clutch pedal ) Post: #1 | |||
Clutch pedal Anyone know how to replace a clutch pedal return spring on a KW T660 | |||
07-15-2017, (Subject: Clutch pedal ) Post: #2 | |||
RE: Clutch pedal Well if its like a w900 its a bitch.... pull off the lower cover on the steering wheel and look under all the sh#t thats in the way and you can see (sort of) where it go's..theres a place for the spring on the pedal and it hook's on a deal up under there.. its a pita's just make sure you look at what needs to be removed so you can see where it go's and make sure you got the spring snug. it a cheep fix just a pita. | |||
