08-19-2017,
Found it! Wasn't the turbo gasket. The manifold had one very loose and one not very night bolt on the bottom center. Snugged those....noise gone!
Super happy....thank you all. I am not completely satisfied that it is making the power it should.....but I am not completely finished with the EGR tune up...and it has a couple of faults I need to get the codes for and check.....but they could have been from the EGR hose that I fixed or any number of other things. One step at a time getting closer. At least it sounds good!
