02-10-2017,
02-10-2017,
02-10-2017,
(02-10-2017 )Brock Wrote: [ -> ]Sorry, I'm referring to the OEM ones.
Was wondering. I had one person who did have a pro-ride system where the drivers side mount weld broke. They sent him a new updated one right away free of charge. Other than that, I haven't heard anything bad from it so far.
The one I installed on my own truck seems to be holding up just fine since last april. Hopefully I will not have any issues with it. It has already out-lasted the OEM system and still going strong.
02-16-2017,
[attachment=2483]
[attachment=2484]
Got it installed. Looks good, feels good inside the cab for the little driving I did but my shocks were screwed so I wouldn't be able to tell if they were better than factory.
[attachment=2484]
02-16-2017,
That red wire running across the back is exposed wiring. A D.O.T. violation.
02-16-2017,
Lol I knew you would catch that! That was a quick 2 minute -40c patch to give my driver work light. It's now fixed after this pic was taken.
09-07-2018,
Anybody have a Parr number for these airbags on the proride system. Mine just got a pin hole and is leaking. I know I should have wrote down the number before installing....
09-07-2018,
http://rawze.com/forums/showthread.php?tid=2114 see post #9
Airbag: Firestone WO2358 7093
Shock: Gabriel 83009
These numbers came on a paper included with my Pro-ride.
My Pro-ride is about a year old and I just had to replace a bag too. I didn't know where I put the part numbers, but just used my phone to read this post. Love Rawze's website.
09-21-2018,
Proride just updated their product, it comes now with 4 air-bags instead of 2, they said it will last longer. New price 750 plus shipping. I just ordered one anyway, it's cheaper than changing OEM bags every year.
11-01-2020,
(02-10-2017 )Rawze Wrote: [ -> ]Not trying to advertise for them, I am usually the one who be quick to point out most non-oem products for inferior quality, etc. but proride cab suspension is the way to go on a prostar instead of putting factory replacement bags back on it.
imk going to be looking in the spring for this
thanks RAWZ
