10-22-2017,
10-22-2017,
Does anybody know if you lived in Mexico , If you could just weld the valve shut ?
10-22-2017,
just re-weld the pipe flange where it is leaking. It is one of the more common places for the EGR to leak.
10-23-2017,
(10-22-2017 )Rawze Wrote: [ -> ]just re-weld the pipe flange where it is leaking. It is one of the more common places for the EGR to leak.
Thanks ,I should go home and use my new welder , 2-1/2 hrs one way + missed work .I'll limp though tonight , and pull it tomorrow and find a shop . I'll sit most the night anyway .
