|  Boost leak  |
|  10-22-2017, (Subject: Boost leak )  Post: #1 | |||
| Boost leak  This is a new one on me , thanks hammer your right again, lol  User's Signature: The missing link | |||
|  10-22-2017, (Subject: Boost leak )  Post: #2 | |||
| RE: Boost leak  Does anybody know if you lived in Mexico , If you could just weld the valve shut ?  User's Signature: The missing link | |||
|  10-22-2017, (Subject: Boost leak )  Post: #3 | |||
| RE: Boost leak  just re-weld the pipe flange where it is leaking. It is one of the more common places for the EGR to leak.  User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
|  10-23-2017, (Subject: Boost leak )  Post: #4 | |||
| RE: Boost leak (10-22-2017 )Rawze Wrote: just re-weld the pipe flange where it is leaking. It is one of the more common places for the EGR to leak. Thanks ,I should go home and use my new welder , 2-1/2 hrs one way + missed work .I'll limp though tonight , and pull it tomorrow and find a shop . I'll sit most the night anyway . User's Signature: The missing link | |||
