Does anybody know the location of clutch switch on 08 pete 386, I need to change it or may be if there is adjustmet. It only works intermit and bcouz of this I can't do parked regen also my cruise and jake brakes stops working.
I can't be sure of the 386 but my old '96 377 the clutch switch was actually under the cab somewhere on the linkage, outside in all the weather.
It is underneath the cab where the clutch pedal pivots. You've really got to look to see it. Get ready for sticker shock when you go get a new one!
Replaced mine last year and it's acting up again.
Be sure to check the spring. If it broke the pedal could be falling slightly enough to cause it to switch. Hook a bungee strap to the pedal and drive down the road and see if cruise works.
