03-26-2016,
Yes I have learned alot & thank you Rawze & the other good guys on the forum hope the gentleman that started this post finds his problem , Good day
(03-25-2016 )Rawze Wrote: [ -> ](03-25-2016 )Bulljammer Wrote: [ -> ]Just updated the post with more info Rawze.
Sounds like the "other forum" is taking guesses. If an injector is bad, it will leak, or not fire a cylinder much at all, or continue to fire a cylinder when it is not supposed to. - If the leak-down passes, and each cylinder fires and runs the motor generally well, the injector is most likely good. If an injector was/is bad, it will leak, and/or the engine would die almost immediately, run rough etc. It sounds like someone wasted money on injector that may not have been bad. Did they even do an injector leak test first? -- I doubt it.
I have heard lots of bullshit stories where guys "claim to hear" subtle differences, like cutting out only one injector, listening for very subtle pinging or other differences, subtle rpm fluctuations etc. It is pure bullshit!. If there is not something VERY significant, and VERY noticeable, not subtle, then there is no evidence of a failing component. To replace parts just because there is a very slight fluctuation etc. is wasting money and blindly guessing hands down!.
I do not run my truck on "guessing" bullshit results. No one else should either.
If you got 6 injectors that are very old, 3 of them are now leaky and failing, -- A logical "guess" would be to conclude that your likely facing all 6 being worn out. -- Is that a guess -- sure,.. but a logical one that makes sense and has merit based on normal component wear and the laws of physics.
To blindly look for obscure subtleties in an engine, trying to compare already old, worn components with little or no merit is not a logical "guess". It would be normal for there to be differences, so the only thing that can be relied upon is significant differences, like finding an actual leaky component, or one that significantly does not perform well and causes significant engine problems. Anything less is generally a waste of time, and changing components based on such subtleties is pure guessing and will not likely produce results that warrant the component change.
Just my own Bullshit $0.02 cents worth on it any ways. My own truck breaks still 9 mpg all day long, and the engine is now surging at idle, runs a bit rough, etc. Are the actuators worn out -- Hell yes, they got 960,000 miles on them!. Are the injectors worn out? -- Hell yes, they got that many miles too!. Am I going to replace them? -- Not until I do my inframe, and even then, I do so reluctantly, but only because the engine is now surging at idle sometimes, and not because the components are old, or have subtle differences.
When there is clear cut evidence of a failing component, or one that will fail in "x" number of hours on my truck, I replace it before it becomes a problem. Otherwise, I run the damn thing down the road and not worry too much about it because that is in fact what its purpose is. To make me money and get every last ounce of component life I can before having to spend money on component replacement. In the mean time, I look for signs of failure or concern, but only take note of them until the evidence is clear enough for me to make a decision without having to "guess blindly" unless I have no other choice, and it is rendering my truck unreliable or un-profitable. - Even then, I will only replace something on a "guess" or "suspicion" if that component has lived well past its expected lifespan already, and there is no way to test it on another vehicle etc.. This way it is not a wasted expense.
(03-27-2016 )Rawze Wrote: [ -> ]I had one once that would not run for crap on cylinder #2. It would even stall the engine sometimes when firing it on only that injector. All other cylinders ran and fired great otherwise. We swapped the injector into number 4, and guess what! -- Number 2 still ran like crap!. It was wear in the valve seat/head that caused it. The guy just kept driving it like that for another few months, even though he was warned that it could come apart at any time. He eventually had to replace the head because his fuel mileage kept going down more and more.
(03-28-2016 )Bulljammer Wrote: [ -> ]Bad actuator will affect 3 cylinders. Ask your mechanic to remove intake manifold an bare engine in quiet environment. Hissing sound from intake or exhaust at the cylinder top point means bad valves.(03-27-2016 )Rawze Wrote: [ -> ]I had one once that would not run for crap on cylinder #2. It would even stall the engine sometimes when firing it on only that injector. All other cylinders ran and fired great otherwise. We swapped the injector into number 4, and guess what! -- Number 2 still ran like crap!. It was wear in the valve seat/head that caused it. The guy just kept driving it like that for another few months, even though he was warned that it could come apart at any time. He eventually had to replace the head because his fuel mileage kept going down more and more.
I talked to the mechanic this morning and let him know that the cylinder is reacting the same way it was before we put the new injector in. His thought was that it could be a compression problem or the actuator. So is he going down a false road or is that possible? I am so discourage from one thing after another.
