Full Version: Anyone lower front end on kw t660?
Needing new steer tires here soon and wanted to lower the front of my t660. I know I can remove the block under springs but can the springs just lay on the axle or do I need a thin plate for springs to sit on? Also will need smaller u bolts and shocks. Anyone have any part numbers?
Gotta have them shims to keep the caster/camber right. Dunno what height block is under it but a good alignment shop should be able to get thinner shim blocks (and get it cruisin better than factory)
Reference URL's
