02-25-2018,
02-25-2018,
(02-25-2018 )Chamberpains Wrote: [ -> ]What do your anchor pins look like? Are they hole ovaled out in the spider?
Brand new spider with a brand new pin
02-25-2018,
Turned the rollers down to this size and the drum will slide on. Wtf[attachment=3635]
Unilevers
02-25-2018,
you do realize that by turning down the rollers you are opening yourself up to a legal shitstorm right? If that trucks causes any issues on the road and they find it has altered brake components - you might as well flee the country. what your doing is not the answer. Its like saying my foot is swollen 3 times the size but rather than fix your broken foot you are just going to wear bigger shoes.....
take it to a shop and get it fixed properly, your having this much issue and its dragging on just take it to a qualified person you trust and have em sort it out and move on and get back on the road.
02-25-2018,
(02-25-2018 )Unilevers Wrote: [ -> ]you do realize that by turning down the rollers you are opening yourself up to a legal shitstorm right? If that trucks causes any issues on the road and they find it has altered brake components - you might as well flee the country. what your doing is not the answer. Its like saying my foot is swollen 3 times the size but rather than fix your broken foot you are just going to wear bigger shoes.....
I understand entirely.
02-25-2018,
Under CVSA you sir are OOS. Plus seeing that pic of the cam what i can tell is it aint the right camshaft. Its not eaton nor q+.
02-25-2018,
Uh huh
02-25-2018,
Uh huh
02-25-2018,
(02-25-2018 )Starlight Wrote: [ -> ]Under CVSA you sir are OOS. Plus seeing that pic of the cam what i can tell is it aint the right camshaft. Its not eaton nor q+.
It's the same cam that's been in it for years and the same cam as the other ones and the same cam as the brand new one I have in the box right from kenworth based on the last six of my vin.
