04-13-2018,
(04-13-2018 )pearce trucking Wrote: [ -> ]Those dimes can turn right at the passage in the second pic if you aren't careful.
Instructions unclear, fed metal fragments into lubrication system.
(04-13-2018 )Unilevers Wrote: [ -> ]im very confused. you put dimes where and they went where? if you put them where they are supposed to go there is no way than can go anywhere and have done this dozens of times with 0 issues.
(04-13-2018 )Unilevers Wrote: [ -> ]what side of the spring did you put the dimes? bore side or dog bone cup side? A or B?A. Dimes first, then spring.
(04-13-2018 )pearce trucking Wrote: [ -> ](04-13-2018 )Unilevers Wrote: [ -> ]im very confused. you put dimes where and they went where? if you put them where they are supposed to go there is no way than can go anywhere and have done this dozens of times with 0 issues.
They went in the regulator bore like they're supposed to. The oil pump was on the motor and the bottom coolant pipe was partially blocking my view inside the bore. I put five dimes in and I guess 2 got lodged cross ways and pushed to the right into the main pump housing. There is approximately a 2" dead end at the back of the bore where the dimes are supposed to go. 3 dimes made it there, but 2 ended up going through the pump. A piece of one of those is in my prior pick. The other 1.75 are MIA. I'm assuming they got caught by the oil thermostat and plugged the rifle. I'm tearing down the oil cooler to inspect. I have new oil cooler, oil thermostat, and oil pump, along with accouterments en route. Might as well replace the oil cooler while I'm there I figure. Also will take egr cooler to cummins for pressure test. Having the oil pressure problems I was having before the dimes, I wouldn't be surprised to find some other debris around the thermostat. While disassembled I'll make certain the rifle between the pump and thermostat is completely clean as well.
(04-13-2018 )pearce trucking Wrote: [ -> ](04-13-2018 )Unilevers Wrote: [ -> ]what side of the spring did you put the dimes? bore side or dog bone cup side? A or B?A. Dimes first, then spring.
(04-13-2018 )Rawze Wrote: [ -> ](04-13-2018 )pearce trucking Wrote: [ -> ](04-13-2018 )Unilevers Wrote: [ -> ]im very confused. you put dimes where and they went where? if you put them where they are supposed to go there is no way than can go anywhere and have done this dozens of times with 0 issues.
You made some kind of mistake. Simple as that. Wrong placement or too many of them. My youtube video shows how most guys do it. I used 1/2" worth of them.
https://www.youtube.com/watch?v=IHaDYh1D...w&index=39
