04-19-2018,
I have my Volvo brakes acting up and ABS module is under suspicious. No any codes on dash. I have Bendix software to diagnose the ABS module but it wont work as it says in Bendix manual. Software properly identify ABS module which is EC-60 but when I try to connect to the module and read stored codes it says FAIL TO COMMUNICATE.
I ask you, if you have Inline adapter, to download and install Bendix software and try to read your ABS module to check is it working.
Sftware is here http://www.bendix.com/en/servicessupport...acom65.jsp on very bottom.
Any question how to install or run please PM me and I will call you.
Thank you.
Thank you.
