There's a place selling fuel tank straps for my ProStar but they don't come with the T-Bolt. Is it even possible to install one? I thought the T-Bolt had to come with the strap.
I bought mine at the dealer, the T bolt came installed in the strap. I don't know how you would add one to a strap, unless you did some cutting, bending and welding. That T bolt is what holds the weight of the tanks.
I think Four State had the straps, the stainless ones with the T bolt. Price was much cheaper for the stainless vs the dealership price. If you just need the black with the step attachment, the dealer is the best place once you figure in shipping. I went with the dealer for this reason.
I think I posted here before about Four State Trucks having them. I'm headed to Texas and just figured it's only 40 miles off route (but unfortunately a lot extra 2 lane highway) to swing by there. I've never been there before so I'm kind of curious to check the place out too. I'm glad you reminded me of them.
The price was really cheap on these straps: $50 each, but it just bothers me that they don't have T-Bolts and I really don't know how you'd install one. Anyone?
I have the steel ones but they've rusted so bad three have now broken. I'm going to replace them with stainless. I'm surprised there hasn't been a recall.
(05-15-2018 )barf Wrote: [ -> ]I think I posted here before about Four State Trucks having them. I'm headed to Texas and just figured it's only 40 miles off route (but unfortunately a lot extra 2 lane highway) to swing by there. I've never been there before so I'm kind of curious to check the place out too. I'm glad you reminded me of them.
If you end up replacing them with steel, por-15 them with a couple coats + a coat or 2 of flex-seal on them at the bottom where they rust through before the install.
