I'm having a problem with my 2009 kw cm871, and i sure would appreciate some input.
On my last run i noticed my coolant temp's are going to 208F, then the fan kicks in, and the temp's go down to 195f. Then i see my fuel mileage beginning to decline. The dpf light come's on, and i do a stationary regen. Then all is well, fuel mileage is up, and the coolant temp is normal. And before the stationary regen, i'm noticing bluish smoke, only when climbing a hill or mountain, however this bluish smoke goe's away after the stationary regen. I'm hoping the doc is not cracked. If the doc is cracked, wouldn't it have a bluish smoke at all times?
Please advise, much appreciated
Thanks
(07-24-2017 )Waterloo Wrote: [ -> ]Howard! Why have you not MM'd that thing!?!
hell, I've only put 5000 mi on it since getting it all back together. You think your situation was bad, i've had the truck 4 yrs, and only put a 100k miles on her. thank God i had a backup truck, to keep running. mm is the next step.
I'm also trying to get insite installed, and i can't seem to get the software from the disc to the hard drive, another headache
1)Remove laptop from case
2)Open laptop screen
3)Say "Ooh, computer!"
4)Close laptop screen
5)Place Insite CD on top of laptop
6)Congratulations, you have put Insite "ON" your laptop...
LMFAO, somedays my brain scrambles and I had best not touch the computer.
No, I haven't been drinking yet today, this was just a funny...
(07-24-2017 )Hammerhead Wrote: [ -> ]How to put Insite on a laptop...
Sorry Howard...
In case anyone needs help putting oil in their car...
