04-19-2016,
There is a culture out there hell bent of removing the VG (Variable Geometry) turbo's form these modern diesel engines. That culture is the same one that spreads bad EGR deletes like a disease amongst the ECM tuner community!. It is Big-Name Big Dollar EGR Delete Companies and all the other piss poor "Tuner" companies that push these so-called "Stage 1" and "Stage-2" type of EGR deletes. Power mods and such!.
I want to address this properly, and thoroughly once in for all,... It is the debate over "Fixed turbo's" vs "VG (Variable Geometry) turbo's" and the truth behind WHY they make their claims.
Fixed Turbo's vs Variable Geometry Turbo's ...
The question I posed was why someone would want to do such a thing to one of these modern diesel engines? ...
To put this into better perspective, Diesel engines run on fuel and air both, and to make the power needed to move heavy loads, they need extra "Charge Pressure" and "Charge Flow", or Turbo-Boost, as its called. All of these things need to be controlled precisely, and the better control you have over these things, the more efficient you make the engine overall. The differences are a LOT, not a little. It can be the difference between getting 5 mpg or 8 mpg under the same exact load conditions, or 600 Horsepower vs. 1000+ Horsepower before an engine will overheat and/or fail.
Operating a turbocharger outside of its optimal operating zone also has some serious disadvantages. A fixed turbo only has a narrow operating zone of high efficiency, making the engine only have a very narrow rpm band where it will be optimized. The engine will become a lot less fuel and/or power efficient when operated on the highways, streets, and anywhere this exact narrow window of specific RPM range is used. In rpm ranges that are too low for a fixed-type turbocharger, the engine does not produce enough exhaust flow to get the correct intake air flow .. it suffers efficiency due to under-boosting conditions. In rpm ranges that are too high, the turbo has to deal with excess exhaust flow in some way so that it does not over-spool or over-boost the engine. This requires a waste-gate to bleed off the excess exhaust that is not needed.
On these newer diesels, the turbo is also that exact thing that controls the correct fuel-air-mix for the engine too. Run one of these newer engines too lean, and its excess internal friction, liner issues, and all the other bad things that happen to them prematurely. Run one too rich and you create a lot of excess exhaust heat, you loose efficiency like mad. This leads to significantly lower fuel mileage than can be achieved. It also produces soot and black smoke if it gets bad enough, causing all sorts of excess wear, soot-packing, and other issues just like the EGR does.
- A VGT turbo solves every bit of these issues, plain and simple. It keeps the engine at its optimal fuel-air-mix through a very large range of RPM, power, and use.
Lets first look at lower rpm ranges ...
When your sitting at idle and you press the fuel pedal to get you going, the engine needs both fuel and air to get it going. In the case of a big diesel engine, that positive boost pressure assists in making that power by providing extra compression and oxygen. Here is where you encounter the first differences between a fixed style turbo vs a VGT. A fixed turbo will only spool up when higher exhaust flow hits it. This means that the engine has to start reving up and producing power to push it along.
The turbo "reacts" to this and produces boost to help it along as a result. the problem lies in that to get the engine going, you have to pour in more fuel. More fuel requires more air, but the turbo is not providing it yet. This in turn makes it more difficult for the engine to get up an going. It is known as turbo lag. It makes a sort-of "catch-22" type of scenario. More power requires more boost, and to make more boost, you need to be making more power. The only way to overcome this lack of boost is to pour more fuel into the engine, screwing up the proper fuel-air-mix to overcome it. This is why old trucks smoke and make soot out of the stacks when hitting the accelerator. It is all wasted fuel. This is a very inefficient process, especially for someone who has to do a lot of start-stop operations with their vehicle.
How can this be fixed??
With a Variable Geometry turbocharger...
A VG turbocharger can be adjusted on the fly. They have such a wide range of adjustment, that the exhaust at idle alone can be used to spool them up (known as pre-spooling). As soon as the computer sees the accelerator pedal move, it can command the turbo to close its vanes and spool up the turbo quickly, providing boost right away. This allows the engine to produce power with less fuel and prevents the bulk of "black smoke at take off" scenario. The engine fuel-air-mix is also kept to an optimum, making the engine significantly more fuel efficient overall in the lower rpm ranges.
-== Clearly the VG turbo has the advantage! ==-
What about high at rpm and torque???...
At higher rpm and power requirements, the engine starts to make more exhaust than the turbocharger needs. If not dealt with, it causes the turbocharger to over-boost the engine (providing too much oxygen). This causes the fuel to burn too quickly and violently. This lowers the amount of energy going to the flywheel vs. the heat produced and increases internal engine friction by a lot. This is known as high-detonation and excess lateral thrust. The excess boost also causes pressure to build up in the exhaust manifold, "getting in the way" of the pistons coming back up and lowers engine output torque to the flywheel as it labors to push exhaust gasses past this restriction the turbo has on the manifold. Here is how each type of turbo deals with this...
A well designed fixed-vane turbo will have a waste-gate to vent this extra exhaust flow. It is usually adjusted based on air the intake boost it is making. A fixed-vane turbo will start to open this waste-gate and bypass the exhaust turbine wheel, setting an upper limit to the amount of boost at the intake. Newer fixed-vane turbos do this fairly efficiently but there are still to problems to address here. One is that with a waste-gate, the boost is fixed at say 30-psi, or perhaps 35psi.. or whatever the waste-gate is adjusted to. This is less than optimal again for getting the right fuel-air mix into the engine as the engine produces more and more power and rpm. Again, you end up with a fairly narrow "window" of optimum efficiency within a small range of rpm and power.. and anything outside/above this, and there is not enough boost to power ratio again. The waste-gate and/or the turbine housing itself can be modified/adjusted to change where this window is, but it will never be widened for better overall efficiency. You either loose something on the bottom end ... or on the top end of the working engines range.
The slight advantage that a fixed-vane does have when the waste-gate is open ... but only when the engine is in its optimal (+/- 100)RPM band for that turbo...
All turbochargers absorb heat, and all turbochargers transfer that heat into their faces and into the intake boost that they are making. One advantage that a fixed turbo has when the engine IS at that narrow range of peak point of optimization, rpm and power window vss a properly set VGT, is that the extra heat deflected away from the turbo itself due to the waste-gate being open means less heat transfer into the intake/cold side. It also means cooler turbo operating temperatures. This is something that can be an advantage at high engine output in high engine load applications, where the engine is worked hard for extended periods of time at a fairly fixed RPM range. Because of this, there are a few applications that a fixed-turbo will take the lead.. but this is a very limited and specific thing.
NEXT, is the second issue when considering What about high at rpm and torque. That is the fact that almost ZERO deleted engines that I have seen, does anyone even bother to install a waste-gate. This has serious problems, as there is no control of intake boost levels vs. power, making the problems with a fixed-vane on a large engine much more pronounced. Why these delete companies are so ignorant is beyond me... but this is what they do. Some could argue that they have special turbines made or special exhaust housings made.. but this solves nothing. Either the turbo is too lazy at the bottom of the spectrum, or it is far too sensitive at the other.. there is no way to win at all and it is complete garbage-can, redneck rubbish.
But is there any applications where a fixed-vane + waste-gate can be better that a VG turbo ??...
A VG turbocharger with its adjustable vanes can and will have a more precise control of bypassing exhaust gas that is not needed. It clearly is programmable for all situations, including bypassing hot exhaust gas that it does not need. The difference though, is that ALL the exhaust gas flows through the turbocharger housing even if its vanes are open. The turbine absorbs less heat when it is bypassing, but not nearly at the rate a fixed-turbo will. The housing also stays hotter too, making for higher internal temperatures inside the turbo. Combine that with a lot more moving parts, and it becomes clear that a VG turbocharger by design at high engine outputs can certainly have a shorter lifespan than a well designed fixed-vane + waste-gate setup.
It can easily be argued that anything with moving parts in it will inherently have more things to go wrong over time when under high heat stress. My own experience is that WITH a VG turbocharger, heat is the enemy, but that does not mean they are inherently bad devices. It simply means that heat must be managed properly for them to live a long life. It is not unusual to get 500-600k miles out of one, vs 800k miles form a fixed turbo. There are always exceptions, but that seems to be the trend. I have seen VG turbochargers make it past 900K miles and fixed turbos make it past a million. On average, the lifespan difference are about 200k miles or so for most highway trucks.
A person could clearly contend that a fixed turbo has the advantage,.. that is,.. if it has a waste-gate and can be tuned to provide the same efficiency in the rpm range that the truck is driven the most in, -- Hence why some of the ill-informed the "big-power", "big-ego" crowd will sometimes swear by them.
So... the argument rages over them... Which one is clearly better? -- That will likely never be solved, I do see both sides of this story.
I have seen people switch from one to the other, and some have switched back again. So far, the results are always the same when someone does this. Those results are always based on how someone uses their equipment. The people who don't use a lot of power, and don't want to push their engine into the high torque regions for hours on end all day always say the same thing. It the people who drive with fuel savings in mind and don't push their trucks hard. They generally say...
With a fixed turbo, the the low end response of the truck now sucks when taking away from a traffic light. They have to either deal with a whole lot of lag and lack of power on the bottom end, or have the program adjusted to dump in a lot of fuel to get the turbo to spool up and make smoke like an old style inefficient type truck does. Doing so keeps their oil darker and sooty, and it eats up fuel mileage. There is little to no middle ground really. Some have played with their turbo and engine adjustments to minimize it and strike a bit of balance, but it is never nearly as good as a VG turbo can do. Once the engine gets going, the fixed turbo can be made to be close in efficiency to the VG at certain RPM's. For someone who runs at a fixed rpm most of the time, they will report almost the same fuel mileages. The down side though is that they also loose most of their engine brakes too. On most of these modern engines, the VG turbo itself is what sets the strength of the engine brakes. This makes for big problems with people who haul heavy.
With the VG, the low end response is great and the oil in the engine stays cleaner. The VG can be programmed in a much wider range of rpm to provide better engine response combined with an always optimized fuel-air-mix. overall that yields far better fuel mileage. For a truck that is not driven hard, where fuel mileage is top priority, this difference is night and day. it is in the measure of 6 mpg vs 7 or 8 mpg. This is so much so, that the difference is thousands of dollars a year in fuel savings most all cases. This is especially true with trucks that have a lot of stop and go or lighter lower torque requirements (typical highway truck). It more than makes up on savings than the cost of a replacement of a VG vs a fixed turbo by 4 or 5 times over. It just has no comparison and puts money in the bank in the fuel savings alone.
People who drive with big power, big egos and high torque demand...
They are quick to say things like ...
" I like to brag about my fixed turbo and all the modifications I have done. Look at me and my big bad-ass 600+ hp truck and how fast I can take that hill. I get just the same or better fuel mileage than I had with the VG, maybe even better" ... << Of course the reality is that they don't understand that the way they drive and push the equipment around IS the problem in itself. They were pushing it hard before, and they continue to do so. Why would they see any losses? -- They are demanding power and torque at a high rate, and their fuel mileage sucks so badly that they don't see the losses at the bottom end.
They will also say things like...
"With the VG, it was holding me back. It was just too small and I couldn't get more power out of it without high EGT's. Burned up 3 of them in 400k miles because I too much for them, over-spooling them, and pushing them beyond their flow and temp ratings." ... << For them and their thinking, everyone else on the planet should be the same way ... they have somehow convinced themselves that "bigger is better" and no one is going to tell them otherwise. The real issue here is that they are using a BAD DELETE PROGRAM where the VG turbo is not programmed correctly at all. This tortures the turbo and the BAD DELETE SHOP is quick to yank it off there and put a fixed-turbo in its place because they are simply too dumb to take advantage of the VG and program it properly. This is the issue and I gurantee that the engine with that fixed-turbo and horrible delete program in it (because all of them that use fixed-turbo's are horrible).. that engine will live a short lifespan... costing the truck owner an inframe every few years or so... all while they blame the engine and truck.. never realizing that what they did to it by hacking it up so badly WAS THE ISSUE.
Personally, I like my +2 mpg above what a fixed turbo could do on my own truck. This is because fuel mileage is above all with me. That is what makes or breaks my profit margin over time and allows ne to have financial breathing room. The difference in power on the truck with the VG turbo allows for a much better response through BOTH the low AND high rpm ranges, making it much easier for the engine to do its job of moving heavy loads. Having good power in ALL rpm ranges, and not just one narrow band, or above a certain range has large advantages of its own. So, to put it bluntly,... The difference between a fixed vein turbo and a VG turbo is HUGE when it comes to overall fuel savings, engine response, and a far better jake break strength. If your not pushing the crap out of the engine. The adjustably and precice fuel-air-mix control of a VG vs. a fixed is like comparing a pen and paper to chalk scribbles on a cave wall. ... Sure they can convey the same message, but the pen and paper is vastly superior when your not being a cave-man towards how you drive your truck and engine.
At the end of the day, no matter how you tune a Fixed type turbo, or how you set it, it will only ever be 100% efficient at a narrow engine RPM range. You find yourself becoming a slave to this very narrow RPM range after a while and then the costs of re-gearing the truck to get it and keep it there starts to become visible. More expense that is not needed when you have a VG. Fixed turbos are great for a generator where the engine turns the same RPM no matter what, or for a truck that has to work at 80-90% engine load in higher rpm's all day long at a fairly steady speed/rate. -- For a highway truck though, out on the freeways under varying conditions?,... In my book, I say forget it!. That is the technology of yesteryear,.. and it is not something we should look back towards, nor consider any more. Engine technology has far surpassed the days of "fixed vane" turbos in a modern truck.
But... But ... What about Reliability!?... Fixed Turbo's LAST LONGER!!!
I have heard this argument so many times it makes me sick!,... It is the brainwashing of the bad delete companies. It has no merit at all when proper methods are used during and after custom tuning and/or a delete (Assuming you live in a country where it is legal). VG turbo's are far superior in their operation, the efficiency they provide, and far Superior in producing raw power when needed too!,.. BUT they are also more complex. Because of this, there are a lot more moving parts that can fail, making their lifespan shorter than that of a fixed-vein turbo. Like mentioned above, the more moving parts to something, it is more likely to fail, and there are more things to wear out. Because of this, We must consider the cost of these things, and their replacement/reliability vs what we gain from then in return. VG turbo's typically last about 400 - 600k miles if cared for, vs a fixed turbo that might last 800 - 900k miles. On a highway truck moving goods from here to there,... The fuel savings and efficiency of a VG turbo alone, pay for their replacement several times over, so there is no question as to which one is Superior, even in worse case scenarios.
No one "Wants" to break down,.. or replace an expensive VG turbo,.. I understand that, so what I recommend is that people care for their VG turbo's properly. Installing gauges into the dash of the truck to help them minimize boost requirement and to keep turbo temps down via installing a pyro gauge and using better driving habits. This will maximize the life of a VG trubo and allow for a long lifespan form one,. Even if someone does not do this however, they still last a long time, and I have seen many that make it 800 or 900k miles before a replacement when the turbo was not abused.
If an engine is used in some form of competition, where engine efficiency were completely traded away in exchange for raw power, and over-boosting was used to achieve it at the expense of shortening the life of the engine,... IE. A diesel 'Drag-Racing' competition or 'Tractor Pull Contest', in wich case there were absolutely no regard for fuel consumption, efficiency, or longevity whatsoever,... A fixed vein turbo might make the difference between surviving the pull long enough to get the trophy, or stalling out half way down the track with a failed turbo that has absorbed more heat. I certainly get that,... and I get the fact that there is something to be said about increased reliability when torturing somethng,... but at the same time,.. a VG in that same situation can be programmed to NOT over-pool, and NOT over-boost like mad,.. placing the engine in a higher power band overall, giving that driver the edge to push the limits beyond what his competitors can achieve with their old-school ways. Having the proper charge flow allows for far greater power than simply stuffing more and more air into an engine. It actually makes a wider power band to do so, perhaps giving that edge to that engine. When power starts to fall off due to improper fuel-air-mix, etc. a VG will most likely WIN!.
No matter how you look at it,.. No matter what you have been told, or brainwashed to believe,... in the case of a turbocharger,... and trying to make a living with your equipment,.. A VGT is still the way to go. All one has to do is care for it properly and they will last a long time, and not let you down!.
So Why the Brainwashing??? ...
Those big-name Big-Dollar brain butcher delete companies (names not mentioned but everyone knows them) who try to brainwash and dupe their customers into buying non-vg turbos to replace their VGT's do so out of sheer ignorance and for higher profits!. All those companies, and many more, ALWAYS claim that VGT's are junk, so I have chosen to respond to this properly, and with detail for others who are, or have considered such a thing...
First of all,... Sadly enough,... Those same companies who claim these things, ABSOLUTELY DO NOT KNOW HOW TO PROGRAM A VG TURBO AT ALL!> ... YUP,... you hear me right,.... I will repeat myself!!!,... Those same "Big Name" companies have absolutely no clue how to program a VG Turbo, or do it properly!. If they did, then they would have come to the same conclusions a long time ago. Custom ECM tuning, and competition/power tuning should in fact, at the very LEAST, involve 3 basic things. It should involve adjusting the fuelling quantities, the injection timing, AND the FUEL-AIR-MIX properly. ... Only all these companies,.. well,... must have forgotten about the proper fuel-air-mix part of this,... or do not understand that precise control of air pressure (charge pressure) and air flow (charge flow), are as important as the fuel itself!.
Since they do not re-program, or worse,.. many of them actually disable all VG turbo functionality. They then go about mucking up the fueling, timing, and/or make mods to the intake and exhaust components, making them operate incorrectly, and this shorten the engine life-span in a hurry. Because of this, and the fact that they most likely do not understand how to use a VG turbo to the engines advantage .. nor how to properly program one .. They instead, fall back to the archaic methods of a fixed-vein turbo to get the engine to operate again in a somewhat reliable manner... Only a bit of efficiency is lost,.... and a bit of the performance is dulled,.. and all the other negative things that a fixed type turbo is going to be notorious for, will start showing its ugly face.
What they essentially do is knock the engine back into the stone age out of sheer ignorance, claiming that it is the only way to make one of these modern engines reliable, when in fact they are only hiding the fact that they themselves are the ones responsible for destroying that nice VG turbocharger that is capable of MUCH higher efficiency,.. and most of the time, higher engine power output than the fix-turbo they are trying to sell you. ... It is their way of telling you outright, that they do NOT know how to program a modern diesel engine worth a damn!, nor understand what it takes to make one operate efficiently!.
Here is an all to familiar scenario,... This should spell out clearly, why people end up at places like puke delete companies , etc... it is sad indeed!...
An Old-school style truck O/o is ready for a new truck. We will call him Joe for the sake of this scenario. Joe is a successful chap with money to burn, but he knows that he now needs to upgrade his truck for both better fuel efficiency, and because his truck is worn to the bone, ready for an over-seas auction, where he can still fetch a good penny for it. Knowing much about older engines, he goes shopping for a new truck. After some limited research, he decides to buy a new aero-cab peterbuilt with a newer model ISX. He likes the idea of the advertised 'Stronger' engine brake, and presumably better pulling power than the other brands of motors, so he buys one.
300,000 miles later, his EGR and DPF start giving him a fit, and his EGR cooler cracks. He finds out the hard way, that the EGR components only have a 250k warranty, so he shells out a few thousand to the dealer cursing under his breath about it. He has no clue that he could have just done a bit of scheduled maintenance (the occasional EGR tune-up work) to prevent all of it but that is a different story ... Most truck owners have this sickening "drive it till it breaks" mentality and that is what clearly gets them into trouble these days. -- 3-weeks out of the shop, and its down again. This time, its a new DPF for a couple thousand more. 2 months go by, and guess what. Engine derate for the EGR valve. Problem after Problem it seems, from this EGR crap that no one at all maintained whatsoever, now all the problems have set in due to severe neglect, and now it seems there is no end in sight. He knows if he doesn't do something, he is going to go broke, or perhaps worse, loose his long time, well paying customers due to missing scheduled pick-ups and deliveries. One day, he hears some Ill-begotten super-trucker brag how one of those big-name companies who advertise heavily can remove all that crap and solving all his problems.
He calls them up, and after a few e-mails and legal wavers, he sends them his ECM. At this point, he cannot afford so easily, the after-market turbo that they heavily suggest for an additional $6,000 with mounting kit, so he only does the ECM for now. 4 days and a few thousands of $$$ later, he installs the new ECM and hollows out his DPF, etc. throwing away all the EGR junk, welding the pipes shut. At first he is utterly impressed, WoW, such power .. and the dash is saying higher fuel mileage, but when he measures it against the pump on paper, he finds out that the dash in lying and the actual fuel mileage is nothing to bag about. Well, he thinks to himself, at least the downtime is over and my engine is reliable agai... ......,POOOW!,.....His turbo EXPLODES internally, putting him on the side of the road. He thinks to himself, WoW, those Big-Name Delete guys were not kidding when they warned me about my junky VGT, they called it outright!. He thinks to himself,.. (but in reality,.. THEY PROGRAMMED IT TO EXPLODE but joe does not know this),.. but wait,...they want another 6k, and they are closed for the holiday.
Crap!, I need a turbo now!. Well, trying to convince himself that it might just have been coincidence, he gets a new VGT from the dealer for several thousands of $$$. Now he is another $5,700 in the hole after towing, etc., but he got his load delivered. At this point, he is now cursing and hating this 'Red Motor' for more reasons than he can count. Doubtful of its reliability now, he is paying very close attention to how it operates. His idle is rough, and it sounds 'Air-Ish', almost like the engine fan is on, but not as loud. He is also noticing that it overheats easily, and that it just does not 'like' all the extra power that big delete company gave it even though he told them he did not want it turned up, so he drives it more carefully, avoiding it.
A few months later, late at night on a lonely stretch of road, out of nowhere, ... ...POOOW,...SCEEEEECH!!!!,...His new VGT has failed again!!!,...Well, at least it has a warranty right,...?,...so he calls the dealer and gets towed again. They replace his turbo AGAIN, claiming it must have been a bad RE-MAN. Joe, at this point is doubtful, but he accepts it. Well, at least this time it was free but that 4 days down time and towing hurts the wallet. Now, really babying his truck, avoiding all that power they supposedly gave him, he is set on saving the money for that after-market, supposedly, indestructible turbo. A month goes by, then 2. Perhaps it was just a bad RE-MAN. A heavy load or 3, still running strong, but man, its easy to overheat that motor now.
Then one hot summer day, A tall mountian, he crests, and throws the jakes on high because he knows he is heavy. Down he goes, the motor holding back that 80,000 lbs,...1300, 1400, 1500 RPM's,.....1600, 1750, 1800,....its settling out,...ok, I will let it stay up and hold where it s,...... ;;;;;,. ..wha?,.... ,...BAM,.....BAM,.....BAM,.....BAM,... ,...he slams on the brakes,...white smoke boiling out the stack,...he smokes to a stop,....BAM,.....BAM,.....BAM,...he shuts it down. Another shop, another problem. What a !#$@%%@ Q!#@%$@% Q#$@%#$^%#% junk!!! 'Red Motor' !@$$@$@!!!!, as the mechanic shows him the photo off the boroscope of his cracked head, spouting "It dropped a valve,... You can see where it touched the top of the piston, and it cracked the head"... "You need a new head".
There is still an extended warranty on the engine, so the mechanic grabs a camera to take photos of the broken valve spring, only,...there is no broken valve spring. Several hours over the phone and several e-mails later, he finds that there are reports of several motors doing this with no apparent mechanical reason. Cummins engineering claims it is due to turbo over-spin as the cause and are not sure why. They send an engineer from their labs. A day later, as the engineer is digging inside the ECM with Calterm, "Yup, sure enough,...your Big-Boy delete has the engine brake tables set to 99%, and there is no control of the VG turbo position any more....It killed the head due to excess exhaust back-pressure.,...Oh,...Look,...your turbo is actually programmed to self destruct! ... It is also set to not give any alarms, as well as being programmed to spin 60% faster than is recommended... ...... ........he droves on,..."...
Like a ton of bricks,...Joe now realizes,...looking back at that conversation with that big-name company,...It is clear now why they want you to buy their turbo,...They already knew yours was going to self destruct.... ... They programmed it that way,....
WHY THOSE ROTTEN @$!$# !#$!q$# #@$!$# #$!$# 34Q134@#%@%@%@%%^@^@$@$%@$!!!!!!!!.....BUT,..BUT Oh, crap!!! now I can't undo this,...all my parts are gone!,...and my DPF too!,.......@$!@$v !#$!34 !#$$#!! 'Red motor' !#$@%#@%..............What do I do now?...
He thinks to himself that he must bow his head and eat the cost of that 'Super-Turbo' they claim to sell to fix this now,...or do I?...Perhaps it won't work,...Maybe it will,... I must now do something, and I feel trapped in their net now, having to rely in them to get me right again...."and oh yea",..The engineer looks at joe,..."This voided your warranty... Have a nice day"...As he leaves.
Several months later, 2 more turbo's, and another cracked head, Joe gets the 'Super-Turbo' Borg Werner kit for another $6,000 out of sheer desperation, and sends his ECM to them again for another $2500 bucks so that they can change ONE SINGLE PAREMETER to allow the retrofit. His truck has suffered much, but he is now happy after all is done. He has now, no engine brake and his engine lost fuel mileage, but not a lot. Maybe only its down .4 from where he had EGR, and .7 from after EGR, but thats only if he drives it in its now, very distinct, 'Sweet Spot', just like his old pre-EGR, Pre-VGT motor had. Now he is looking at spending another $3,000 for re-gearing the truck, so that it will match that fixed turbo "sweet-spot" to improve it a little,...and maybe a Scangauge, micro-blue,...and all the other old school, way overpriced other mods that are nothing but garbage gimmiks too... Perhaps some day he will see 7 - 7.5 mpg out of it after all the mods, who knows... When actually if someone had simply programmed the engine and turbo correctly,.. he would have never had any of those expensive problems, and would be sitting at 8+ mpg... But joe will never know it,.. because those big-name delete companies have brainwashed him real good by now.
Where did Joe go wrong AFTER his new truck purchase?...
Well, It is obvious that he was caught up in the all to familiar endless cycle of 'DPF nightmares'. Some education and a regular 'EGR Tune-up' on his part, would have likely kept him Away from all the delete stuff to begin with. It would also have kept his costs and downtime at a minimum,... but he chose to instead to throw his problems at someone else. Perhaps he would have never done the delete to begin with?,...Who knows. Regardless, Just like most,... Everyone gets tempted by the prospect of 'More Power' and/or 'Better Fuel Economy' via a 'Delete', ... After-all that is what those guys advertise,... so I will move onward,...
His biggest mistake on the delete, was to pay someone good money for an ECM tune that clearly was set up to cause turbo and other eventual failures. A good Custom tune would have had the turbo operate correctly, and within its limits. Would his VGT have failed?,... eventually,... but not for another 300-500k+ miles or more, as a function of normal wear. The EGR itself accelerates this process, so removing the EGR, if mapped correctly, the turbo can potentially last just about as long as a typical fixed type turbo any ways.
He did in fact get a BAD delete,... Those companies leave you with only one option in the end... A turbo that is not controlled by the ECM. This patches the only a small part of the problems in the bad delete, and does so at the cost of fuel mileage, engine efficiency, a terrible power curve, and sacrificing most of the jake brake. Sure they turned up the power of the engine with the ECM,.. but that power is difficult for it to achieve with that now fixed turbo. A well calibrated VGT turbo on a highway truck will easily improve fuel mileage by as much a 2 mpg, and can provide reliable power well beyond the range of that Borg-Werner or Big-Boss crap of a turbo they sell.
This brings me now to the bold statement of "Why someone would want to do something so absolutely stupid". A VGT vs non-VG Very easily yields more than 1-1.5 MPG than a non-vg in its same place on highway vehicles, because RPM, load conditions, and speed, are always changing. A VGT compensates for ALL of this, as well as reducing back-pressure fluctuations greatly, resulting in MUCH higher engine efficiencies. IT IS THEREFORE IMPOSSIBLE for a non-VG turbocharged engine to keep up with this, under varying conditions. A pre-EGR, pre-VG engine (ie. Gliders), CANNOT HOLD A CANDLE to a Custom tuned, efficiently programmed VGT Engine with its VG turbo!.
THATS WHY MY TRUCK KICKS THE TEETH OUT OF THOSE GLIDER KITS ALL DAY LONG! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! GET OVER IT!!!!!!!!!
Screw you and your ignorant pre-egr, pre-VG Brain-washig Glider-kid junkyard trucks!!!!
I will replace my holset at 600-800+k and smile quietly, counting my profits.
It seems that I have a strong dislike for a few of the 'Super-Tuner' shops out there,...I suppose it is because I have revealed their bad practices to the world, and the more I, and others discover, ... The more the average truck owner, considering such things, should be aware of, and concerned about.
I ask for nothing in return, nor am trying to promote myself, or any products. I just like to help other truck owners, nothing more,... and am well known on several other trucking and ECM editing forums to be the loudmouth that reveals all the bad practices and dirty secrets that they do not want others to know about... I am disliked by just about all of the 'Super-Tuner' multi-million rip-off shops, and know it. Some have even offered to pay other forums to shut me up, and others continually threaten this site and what I say because the truth hurts their bottom dollar!.
To them, I have become the one guy who has begun to make them accountable for what they do through educating other truck owners, and it is beginning to hurt their business. I do voice a strong opinion about it at times. I only wish others to learn and discover for themselves, what I have seen, so they can form their own opinion. I have hard evidence, backing what I say toward them,... but I will not post it directly, It would give them an excuse to try and sue me for giving their horribly bad programming away,...
That is WHY I made my own forum,... So that I can post my opinions and information, and it not get deleted like it did over on TTR, and other places!,... and after all this time,.. after several years now, of me revealing their bad ways,.. and bad things they do,... They STILL HAVEN'T CHANGED THEIR WAYS!!!,.. It is sad indeed how these places make so many millions off of truckers and their trucks,.. butchering their engines,... all the while telling them lies!.
It truly makes me sick to my stomach when I hear another O/O brag about them,.. or see their trucks lined up at the truck shows,.. or see someone trying to justify all the money they wasted with those clowns,.. telling themselves that it is "ok"....
IT IS NOT OK !!!!
Conclusion...
- I would not even consider driving a truck with a flat nose,.. or a fixed-type turbocharger! --- I actually want to turn a profit for what i do, and could absolutely care less what the equipment looks like. To me it is simply a truck designed to move freight in the most efficient manner possible, so that it makes me as much money as it can that I can take home and keep!. There is no profit any more in a flat nose,.. or chrome rims and hood scoops,.. and there is no money in old-out of date tech non-vg engines designed to drink fuel at a rapid rate!.--- So as far as I am concerned,... they can ALL go to the junkyard where they belong,.. or to a museum where old farts can brag about the days when fuel costs 3 cents a gallon or whatever it was back then! -- I live in the 21'st century and I am proud of it,.. and I will do what it takes to be profitable above looking good any day. that is what makes me happy,.. and NOT some Dinasuar of a truck with a flat chrome front end that was designed in the 1850's, and a turbo that was designed for a generator!.
And for those who disagree and have old junk trucks they pour endless fuel money into ----
{A half-drunk tired Rawze says --} TAKE THAT JUNKYARD DINOSAUR OF A TRUCK AND GO BRAG ABOUT IT ON TTR WHERE IT BELONGS!!! ---- THIS IS AN ISX AND MODERN ENGINE FORUM!!
Rawze.
IT IS NOT OK !!!!
Conclusion...
Rawze.
