10-10-2018,
Pages: 1 2
10-12-2018,
Hi Rawze.. Did you survive the storm? Everyone ok? I started EGR tune up. I MAP sensor clogged dont know how it even worked..Tomorrow we remove all components and clean. new I map and differential psi sensor! Thanks for all your help! May try your over head set also! Need to get torque wrench you have mentioned the gauge style!
10-12-2018,
(10-12-2018 )Joelbe Wrote: [ -> ]Hi Rawze.. Did you survive the storm? Everyone ok? I started EGR tune up. I MAP sensor clogged dont know how it even worked..Tomorrow we remove all components and clean. new I map and differential psi sensor! Thanks for all your help! May try your over head set also! Need to get torque wrench you have mentioned the gauge style!
all good here, thanks for asking.
10-12-2018,
Rawze, have you ever tried seafoam in a motor? Could this actually clean out a soot filled motor ? Your thoughts?
10-13-2018,
(10-12-2018 )Joelbe Wrote: [ -> ]Rawze, have you ever tried seafoam in a motor? Could this actually clean out a soot filled motor ? Your thoughts?
http://rawze.com/forums/showthread.php?t...6#pid26866
and...
http://rawze.com/forums/showthread.php?t...7#pid16597
and...
http://rawze.com/forums/showthread.php?t...3#pid10573
Simply fix the engine problems that are making it have excess soot, change the oil at shorter than normal intervals a few times, etc. to get it back right.
10-13-2018,
Got it! Thumbs down!
Pages: 1 2
