10-10-2018,
2010 International Lonestar-CM871- stock
Does unplugging the magic plug shut off the EGR and Aftertreatment system?
why im asking is i ran for about 16hrs driving with magic plug undone and didnt regen once shows none in the log on insite untill after being plugged back in.
before i unplugged and now after it was and is regening every 1.5-2hrs of engine key on time
when i make insite do a forced regen aftertreatment dif pressure never goes above 1.0 - inhg sits around .5-.7 but my history shows regens at 3.5-4.5 while driving
also should i be seeing 15PSI fuel pressure on doser fuel pressure sensor when doser is off. not sure if this is a PSI-A or PSI-G sensor.
