whats the best or less $$ way to abtain the INSITE and whats it come with
been looking the web cummins couldnt download ??
tryed to stay away from the electronic world,but i know better.
so im looking for info mybe im going the rong rout ?
I put a thread out of getting insite. You can buy the cheap adapters on Ebay from China for less than $300 with the CD included to download the program onto your laptop. The seller should have the PC ID to log in after you install the program onto your laptop.
Download 7.6, the. Update manager, then 7.61, and finally 7.62.
piced one lastnight ebay 310. shiped will see,supose programand all wiress.
then its me learning it--islowed my mec work as electron camin more and more
8.2.0 or 8 sumthin that was lastnight ??
now i gota work on tire sizn for rpm dif 22.5 lowpro or talls / or maybe go to24.5 tall
iv got 22.5 low
any one
(10-29-2018 )shoe128 Wrote: [ -> ]piced one lastnight ebay 310. shiped will see,supose programand all wiress.
iv got 22.5 low
any one
Maybe take the time to write out what you want to say at east half-way correctly instead of that broken cryptic texting? -- That or use a better translator.
I have no idea what half the things you were trying to say there. Hopefully you are not texting that mess while going down the roads.
