12-09-2018,
Hi,
I have a 1994 Kenworth with a N14 in a dump truck. we had the engine inframed a few years ago and its been pretty much trouble free since i've owned it. Just yesterday it was running fine, then without warning, it just stopped. It will crank but won't start. I check the wire to the fuel pump solenoid, and there is no power to it. We ran a jumper wire to the solenoid, and it started right up. There seems to be intermittant power to the solenoid wire. I changed the ignition switch cause it was cheap and was very loose, thought maybe it was failing, but it didn't seem to help. I'm thinking it might be the ECM? Would anyone have any ideas of what i should check or is there some way to test it?
Thanks
Thanks
