02-08-2020,
(02-08-2020 )Neighbor Wrote: [ -> ]Believe it or not when I worked at a small stealership, Cummins would wash them out with some type of solution but this was 7 or 8 years ago. After I found that out the Co. quit sending them over there. How I discovered this was I would always blow shop air thru the filter with a blow gun and a crap load of clear liquid would came out the back. I have no idea if they still do this like I said it has been a long time ago.
I have been in a couple of the stealers$its that actually have the proper (very expensive) cleaning machines recommended by the red engine maker.
They use ...
* A heating oven (1300+ degrees I think), to bake them so that it turns all the contaminants into ash.
* they then use a machine with an air-knife and high pressure, dried air to blow out the ash, flipping it over during the process.
* then they inspect it for cracks and damage.
* Then they put it on an air machine to flow-test it.
-- AT NO POINT is there any liquid that can wash the platinum /precious metals out of the canisters, nor does this method attempt to clear out all the holes that are supposed to be blocked off on the back side ... YES, that is right,.. 50% of the DPF element IS SUPPOSED TO BE BLOCKED OFF at the back end of it to assist in trapping soot.
