04-24-2019,
Pages: 1 2
04-25-2019,
screws breaking repeatedly =...
* uneven mounting surface (maybe you are using the wrong type of gasket?. Dirt? OR... There are 2 different types of actuators. Some use a metal flat gasket, others use an o-ring.
* Over-torquing the nscrews when installing. -- USE A TORQUE WRENCH. TORQUE ACCORDING TO QUICKSERV. AND STOP GUESSING!.
* Pressure regulator / pressure relief valve in IFSM is going bad.
* The 6mm bleeder for the injector passage is clogged and fuel is expanding, blowing out the actuator after it expands.
* crud in the actuator dampers in the back of the IFSM.
https://youtu.be/MWiSwgcwIoc
and...
https://youtu.be/_WeiDC6S8Lw
and...
Pages: 1 2
