07-14-2019,
Good Morning,
Sure would appreciate you professional guys opinions... Bought a new-to-us RV equipped with a completely stock November 2005 manufacture date Detroit Diesel Series 60 DDEC-V with 92,000 miles on it.
Previously we owned a 1997 rv with a purely mechanical Cummins C8.3 which was GREAT and that I maintained my self. (oil, coolant, hydraulic fluid filter changes etc , muffler delete, alternator, thermostats, air bags, shocks, ac, and more)
I always changed my oil every 5,000 miles and will do the same on this Detroit. Just prior to this first run, the oil was changed and now with only two thousand miles on it, it is as black as night.
The wife and me will likely only drive ten thousand miles a year, so wondering if a de-mandate or anything else would even be worth while or if we should just leave it completely stock.
Also, if there is anything I should do to it maintenance-wise, I sure would appreciate knowing that too as we really need this engine to last us the next 10+ years. I did get the over-head done at 92,000 miles and it did make the engine idle more smoothly.
Oh....on that old purely mechanical C8.3 I deleted the muffler and that made a significant difference. Has anyone done a muffler delete on a Series 60 or replaced the original with a better more flow through muffler?
THANK YOU VERY MUCH for sharing your time and experience! Jeff
