08-19-2019,
Alright guys need some help , I am at end of my rope here.
2010 Lonestar - Cummins Sleeper Truck
Have cold AC in sleeper but not in the Cab.
All Actuator Doors are working - 1 Mounted top Fan , 2 behind Fan Unit under Fusebox -
Blend Door mounted on Firewall I am Assuming is working correct, opens and closes. It should be closed for AC to restrict Hot Air from Engine Comp out - It is fully Closed
New COmpressor, Drier, Evap , Exp Valve, 3 lbs Freon (Have AC Machine)
There is no Hand Valve on Coolant LIne to turn off Water to Heater Core IN Dash but again appears Blend Doors are Functioning which is restricting any of the air passing through heater Core.
First unit we have had with Thermister - Could they have anything to do with the issue. But again Sleeper has Cold AC -
There are 2 Thermister on Drier/Evap.
Does the sleeper have its on functioning Thermister's? I know it has its on Exp valve
Also Changed all Filters -
Any ideas
Any ideas
