Looking for recommendations on a mechanic in the Laurel, MS area off of I-59. 2014 Peterbilt with ISX. Smelt burning clutch, fan isn’t running at speed like it should and a/c started blowing hot. Coolant and oil temps good at highway speed but get warm, 210 or so, once parked. Not sure if clutch went out on fan or high pressure switch went out. Any recommendations on a mechanic between Laurel, MS and Houston, TX?
Thanks
(08-26-2019 )Z7Mike Wrote: [ -> ]Looking for recommendations on a mechanic in the Laurel, MS area off of I-59. 2014 Peterbilt with ISX. Smelt burning clutch, fan isn’t running at speed like it should and a/c started blowing hot. Coolant and oil temps good at highway speed but get warm, 210 or so, once parked. Not sure if clutch went out on fan or high pressure switch went out. Any recommendations on a mechanic between Laurel, MS and Houston, TX?
Thanks
I stay 20 minutes from laurel. Try Burroughs Diesel
(08-26-2019 )david24 Wrote: [ -> ] (08-26-2019 )Z7Mike Wrote: [ -> ]Looking for recommendations on a mechanic in the Laurel, MS area off of I-59. 2014 Peterbilt with ISX. Smelt burning clutch, fan isn’t running at speed like it should and a/c started blowing hot. Coolant and oil temps good at highway speed but get warm, 210 or so, once parked. Not sure if clutch went out on fan or high pressure switch went out. Any recommendations on a mechanic between Laurel, MS and Houston, TX?
Thanks
I’ll call them first thing in morning. Thanks
