09-12-2019,
Can anyone tell me which version of Insite is recommended for CM2250 or CM2350? Best place to purchase?
(09-12-2019 )tree98 Wrote: [ -> ]Most guys on here are using insite 7.6.2 with an inline 5 or 6 adapter. You can get the Chinese version from ebay.
https://rover.ebay.com/rover/0/0/0?mpre=...4393615601
Might be cheaper ones to, this is just the first one I came across.
(10-26-2019 )GreenBean Wrote: [ -> ](09-12-2019 )tree98 Wrote: [ -> ]Most guys on here are using insite 7.6.2 with an inline 5 or 6 adapter. You can get the Chinese version from ebay.
Does this program require a password or registration through a Cummins Dealer? Monthly subscription fee?
(10-26-2019 )Waterloo Wrote: [ -> ](10-26-2019 )GreenBean Wrote: [ -> ](09-12-2019 )tree98 Wrote: [ -> ]Most guys on here are using insite 7.6.2 with an inline 5 or 6 adapter. You can get the Chinese version from ebay.
You should be good to go with the eBay kit, everything should be there for you to operate it out of the box without fees.
(10-26-2019 )GreenBean Wrote: [ -> ](10-26-2019 )Waterloo Wrote: [ -> ](10-26-2019 )GreenBean Wrote: [ -> ](09-12-2019 )tree98 Wrote: [ -> ]Most guys on here are using insite 7.6.2 with an inline 5 or 6 adapter. You can get the Chinese version from ebay.
O.k., Then maybe I'm missing something. I installed on the laptop, hooked it up and the first thing...I get a pop-up message saying that I need to register the product with a cummins dealer and receive a password?
