10-24-2019,
10-24-2019,
Take it to a dealer or shop that bakes, and tests them. Remember, if you have a DOC filter with the DPF, they both need to be baked, cleaned and flow tested. I think you can only bake them twice and then they are junk.
As far as doing it yourself, don't, you do not have the equipment to do it properly, and will destroy the cans. Take them to a shop and pray they actually do the work you are paying for. If you can, stay and watch, that way you know the work was completed.
And I would do an EGR Tuneup while the cans are off, at least inspect the system.
You will need Insite to reset the the emissions too...
