04-23-2020,
04-23-2020,
(04-23-2020 )Rawze Wrote: [ -> ](04-23-2020 )Brock Wrote: [ -> ]I pulled a factory file from another member with a twin truck to mine, I ran the mm2w overlay then put it in my truck and drove it after changing all the parameters for my specific truck them I pulled the file and sent it to you.
I think I changed bunch of truck specific things in the cal as well I may have added 2 degrees on soi for some stupid reason (the timing was already done in the tables so I know I dont need soi) , I wasnt overly concerned doing that as the file was being sent to you before it leaves the yard.
all I know is that, in the file sent to me, that someone added 2+ degrees on the master setting ,.. but it also had +7 in the tables... this is way to much for the isx at high torque.
there are some other things that need to be updated as well before calling that fil
e "good".
maybe your using a severely out of date file or ocverlay?
The overlay I used is out of date but doesn't have the 2 degrees added, I did that myself. I'm guessing the overlay timing table was set up for lower hp.
Good thing I sent it to you before running down the road like a idiot!
