Any input in where I could find a fuel pump new or reman? Cummins isx15 450 cm2250.
I have the old 3 plunger pump and its leaking kenworth quoted me $3,474 for the new 2 plunger pump. Thanks
I thought cummins had a recall on the 3 plunger pumps to replace them.
That’s better than what my quote was for a reman pump. Lol. $3715.19 was my quote
It was $3,747 got the numbers mixed up. I was looking into the recall I think they said it was too late I have a 2013 kwt660 with 587k on it. I guess that's the best deal I'm gonna get on it
You will also need the kit to do the 3 to 2 conversion on it as well..
That sounds pretty good, I did mine a few years ago and was $4600 in with a new pump, two new fuel lines and some sealing washers and such. I was too late for the recall then on my 2012, 2250.
