(01-30-2020 )Rawze Wrote: [ -> ]First thing I always do when someone comes over here is make a pdf document printout of the entire 'Features and parameters' settings that are showing in insite before making any kind of changes. Seen this happen too many times.
- as a last resort, you can pull the ecm off the truck, take it to the stealers%it and have them re-flash the ecm with the latest calibration and restore the original settings for your truck. - Usually costs a few hundred bucks.
I tried to do this, where can i find instructions on the procedure i have a file i would like you to look at.
Thanks
(02-05-2020 )2dlb Wrote: [ -> ] (01-30-2020 )Rawze Wrote: [ -> ]First thing I always do when someone comes over here is make a pdf document printout of the entire 'Features and parameters' settings that are showing in insite before making any kind of changes. Seen this happen too many times.
Thanks
just open up the 'features and parameters' section in insite, expand all, then print it out.
I think doing a complete ecm report, it is included as well.
In modern windows I have win 10 today you can "print to PDF" instead of an actual printer. And it will create a PDF of what you would have printed
