Could anyone tell me how to kill the DRL?
I removed a fuse that says DRL but they are still on. I understand there is a module but I have no idea where is it at.
I can't help on this one. But I have to ask, why do you want to disconnect them?
If memory serves me right, there is some kind of mandatory safety issue/regulation thing Maybe pushed by the manufacturers? on this with trucks beyond a certain year.
unsure though.
When I ordered my 2017 the daytime running light were a option and I can kill them with the dash controller turn knob
(02-22-2020 )Rawze Wrote: [ -> ]If memory serves me right, there is some kind of mandatory safety issue/regulation thing Maybe pushed by the manufacturers? on this with trucks beyond a certain year.
unsure though.
pretty sure Canada mandates driving lights when headlights not in use.
A lot of states require you to have headlights on when the wipers are on. Virginia is well known to enforce this law. DRL has kept me in compliance even when I forget to flip the headlight switch.
I did this on mine cause I wanted my DRL to be on a seperate light instead of my actual headlight, above my clutch pedal there is a sensor in one of the airlines that's labelled for DRL, unplug the switch and run a jumper wire on the plug, tape it and call it a day.
May be able to use esa to disable it as well but I havent played with it yet.
The main reason I want to disconnect them is because I want to be able to control the lights.
If someone is passing me I like to let them know when is safe by turning them off or on day time, the other is because most times I am getting in to the yard at dark and I hate lighting people when not necessarily, I just installed LED lights and they are bright!!
I got this truck from NY and it was from Canada that is the reason it has the DRL, Brock thanks I’ll try it tomorrow
(02-23-2020 )LLT Wrote: [ -> ]The main reason I want to disconnect them is because I want to be able to control the lights.
Use esa to disable on chassis node, electronic service analyst.
