03-05-2020,
(03-05-2020 )Rawze Wrote: [ -> ](03-05-2020 )Edjahman Wrote: [ -> ]OK thank you. I'll give it another go tomorrow.
Appreciate the responses!
Just some related FYI:
For the CM871 engines ...
If your trying to remove the EGR temp sensor plug off a CM871, the older style sensor and plug are glued together and not meant to come apart. This older style will also have a thick layer of heat-shrink wrap over the whole plug to indicate that it is not supposed to come apart. - If someone has this type of shrink-wrapped sensor/plug, they follow the wire back up the harness, then buried back about 1 foot or so back from the plug is another in-line plug. That plug is where it is intended to be removed from and not by cutting away the heat shrink at the sensor itself.
Thank you for the information.
