04-13-2020,
Hi I have a 2002 Mack CL733 with a factory Signature 600. The truck has 320K miles on it and when I got it with 300K it had a intermittent lope at idle and the jake brake did not work. I had it repaired at the local Kenworth Dealer (Local Mack Dealer sucks). They replaced injectors 5 and 6. They rebuild the engine shut down solenoid and rewired the idle validation switch to make the Jake work(They said it was wired backwards). The Lope went away but the truck still has a slight skip. The rough idle clears up after it warns up but the skip is always there. Can anyone point me in the right direction. I replaced the cam and crank sensor but it did not help. Thanks Pete
ESN#14022309
ESN#14022309
