Full Version: Horn noise right side 2012 Cummins isx cm2250
I can move the hose coming out of the fuel pump going thru the electric pump up to the fuel plate. When I move it, the horn sound changes with the movement.
Recently cleaned the actuator to clear a 1347 fm3.
Now the horn noise.
Is it the actuator allowing to much fuel thru with high pressure? Or
Bad fuel pump gears/bearings? Or
Chaffing from theFuel plate behind the ECM that holds the fuel filter?
Any feedback and thoughts before I dump a couple grand into a new fuel pump. Fuel pump parts was upgrade but still original housing and probably gears/bearing/cam.
I have a new actuator that should be here tomorrow. I can eliminate that as soon as that part comes in.
Just scared to get back on road and bust a fuel pump and destroy my motor any more that she could already be.
Your thoughts and a video is attached.
Video is with my iPhone, so it will not attach..
maybe post video on yutube?
https://youtu.be/JckwwWR8Jj8
Starts the horn noise about 12 seconds into the video.
(04-23-2020 )Rawze Wrote: [ -> ]maybe post video on yutube?
Posted and thanks
Well, the new fuel actuator made the engine run smoother, but Im still having the horn like noise while idling and going down the road.
unfortunately it is hard to tell what it is in the video.
Reference URL's
