Full Version: Hood strut rod
Anyone have a go to on the hood strut rodor whatever they call it.
2015 Kenworth T660
Mine decided to break today. The Google prices of $250 or more dollars is not looking good.
maybe a pic of it?
Try these guys, and yes, I realize it is a hood strut, this is where I bought mine, $79 for a ProStar, https://www.truckspring.com/AboutUs.aspx
Or FleetPride...
Here is a couple of pictures.
Waterloo I checked on Michigan spring they have them for a T680 but doesn't list a T660.
Will call fleet pride in the morning. Some folks were off today. Not me, I have to labor on labor day.
(09-07-2020 )Mattman Wrote: [ -> ]Here is a couple of pictures.
you could always resort to using a steel cable set to the correct length if necessary. Just don't let the hood slam open and you'de be fine.
Rawze I did think about a catch cable.
Found a sticker on my old one. Called company that makes them. Can't sell one of those to you.
Called Rush Peterbilt, that's a good part number, but we can't get one. Kenworth only part.
Called MHC Kenworth $300 plus. Dang.
Found online from a dealer in Ohio. $258 shipped to my house. Just think there is two of these strut rods on my truck. When you get into that proprietary stuff you are at their mercy.
(09-08-2020 )Mattman Wrote: [ -> ]Rawze I did think about a catch cable.
the shock-absorbed part of it is basically to prevent the average dummy form slamming the hood open all at once instead of carefully/gently opening it on their own. For the price of $600+ for the pair, i would have made a cable, and just have been mindful to always open the hood slowly so it does not slam open ... that is why I mentioned it above. - if you have other ppl driving the truck though... keeping with the shock would likely be the better solution.
It might also be possible to adapt a less expensive spring-loaded type cable like seen on older trucks too... just a thought.
Those struts come in all different shapes and sizes, I would think that finding one similar would not be that difficult. I wonder if an outfit like Parker would carry them? They are the automation guys, it might be worth making a call or visiting one of their stores if you have one nearby.
Reference URL's
