Thanks, I did find it on the foot pedal. Clean it up seems to be a little better. I think we might have the same egr my motor is a 2009. What venturi are ypu referring to? Also how did you block it off,and is ok do to get it home less than 600 miles?
It's ok to run the truck without the venturi pipe blocked.
Which pipe is it, and how do I do it?
I see that which part do I need to disconnect?
If your truck is running ok, don't disconnect anything until you know everything is ok
It isn't I'm stuck on the side of the road. It will idle but as soon I put it in gear and give some fuel it dies
Have you tried nttsbreakdown.com?
Yes everyone is closed today, or busy with wrecks.
I'm willing to trying anything right to get rolling. Do you know how to {**Content removed by protection bot**- content.}.
