07-05-2021,
I have a 2006 Pete, ISX engine.
I found I had no boost on the high setting for the engine brake. Upon inspection I discovered the actuator doesn't move. Disconnected it from the turbo and found the rod which operates the VG vaines is stuck in its current position. It will NOT move.
Is there a repair or rebuild kit available anywhere that can replace just those parts? The vaines and plate inside??
