Got a new fuel pum for my cm2250, how does the fuel pump go in the gears does it need to be timed? I see a dot on the gears
(08-17-2016 )sbtrucking Wrote: [ -> ]Got a new fuel pum for my cm2250, how does the fuel pump go in the gears does it need to be timed? I see a dot on the gears
The engine needs to be in the "PIN" position on the crank. After that, this is how the gear should be aligned during the install.
It is to prevent excess engine vibration.
How much does a new pump cost?
(08-19-2016 )overshot Wrote: [ -> ] (08-19-2016 )jimeneztrans84 Wrote: [ -> ]Almost 4k
OUCH
That's why I took a gamble and bought a used 2 cylinder pump and just updated the plungers,rollers and tappets.
(08-18-2016 )overshot Wrote: [ -> ]How much does a new pump cost?
I found the pump for 2600 shipped plus around 400 core charge
