Installing fuel pump cm2250
08-17-2016, (Subject: Installing fuel pump cm2250 )
Got a new fuel pum for my cm2250, how does the fuel pump go in the gears does it need to be timed? I see a dot on the gears
./uploads/201608/post_1749_1471451599_0b601f4ee17fdcb7db2106b2b520aaa4.jpeg
RE: Installing fuel pump cm2250
(08-17-2016 )sbtrucking Wrote:  Got a new fuel pum for my cm2250, how does the fuel pump go in the gears does it need to be timed? I see a dot on the gears
QUIKSERVE knows all
The engine needs to be in the "PIN" position on the crank. After that, this is how the gear should be aligned during the install.
It is to prevent excess engine vibration.
./uploads/201608/post_848_1471463142_890b771ed52e31f5f98a026cfa77d62b.png
 Thanks given by: szartman379 , snailexpress , Rounded_nut
With engine pinned
 Thanks given by: Rounded_nut
08-18-2016, (Subject: Installing fuel pump cm2250 )
How much does a new pump cost?
08-19-2016, (Subject: Installing fuel pump cm2250 )
Almost 4k
(08-19-2016 )jimeneztrans84 Wrote:  Almost 4k
OUCH
OUCH
That's why I took a gamble and bought a used 2 cylinder pump and just updated the plungers,rollers and tappets.
08-21-2016, (Subject: Installing fuel pump cm2250 )
(08-18-2016 )overshot Wrote:  How much does a new pump cost?
I found the pump for 2600 shipped plus around 400 core charge
