08-09-2021,
Well I think it finally happened I think I sank the liner since I bought the truck I've been chasing a water loss of about a gallon every 2 months. Last couple weeks it turned into about a half gallon a day. Finally bought a leak test kit off scamazon I had it on the truck all weekend starting Friday found one leak on a hose going to the heater core that was going on the back side of the exhaust thought maybe that was it oil still look fine on Saturday but then when I got ready to pull the kid off on Sunday I was still losing pressure and suddenly my oil was way over full and green and for the first time ever I had water infiltration on my oil fill cap.
Going to take her to the shop just in case I'm lucky enough that it's an oil cooler but I've never had oil in the water only water in the oil and the truck runs a consistent 40 to 45 PSI oil pressure I would think that would overpower the coolant to get in the coolant too it was the oil cooler.
So going to set up for a main and rod Bearing and pressurize it and check it and if water comes out where it shouldn't then she's going down for major surgery.
