09-04-2021,
[attachment=8036]My headlight on driver side went out so I went to replace bulb and found this issue with the wire. I replaced bulb and had to position wire in a certain way to make a better connection. It holds but every once in awhile with all the bumps on road it will go out then on again. Does anyone know what the part # is and can I just cut and reconnect the wire?
