Just wondering if anyone can tell me how to remove the turbo oil return line from the block. It's leaking at the block. I assume there is an o-ring there? Does it just pull out and push in? Thanks.
Yes it just pushes in, it's not really an o-ring it's a rubber seal but your on the right track.
It just pushes in ... here is a seal with a metal ring that needs replacing as well.
When you purchase the new seal, you will see what it looks like.
Got it, thanks fellas. I was able to pop the old one out and press the new one in relatively easy. Easier fix than anticipated lol.
