| Turbo oil return line leak |
| 09-20-2021, (Subject: Turbo oil return line leak ) Post: #1 | |||
| Turbo oil return line leak Just wondering if anyone can tell me how to remove the turbo oil return line from the block. It's leaking at the block. I assume there is an o-ring there? Does it just pull out and push in? Thanks. | |||
| 09-20-2021, (Subject: Turbo oil return line leak ) Post: #2 | |||
| RE: Turbo oil return line leak Yes it just pushes in, it's not really an o-ring it's a rubber seal but your on the right track. | |||
| 09-20-2021, (Subject: Turbo oil return line leak ) Post: #3 | |||
| RE: Turbo oil return line leak It just pushes in ... here is a seal with a metal ring that needs replacing as well. When you purchase the new seal, you will see what it looks like. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 09-20-2021, (Subject: Turbo oil return line leak ) Post: #4 | |||
| RE: Turbo oil return line leak Got it, thanks fellas. I was able to pop the old one out and press the new one in relatively easy. Easier fix than anticipated lol. | |||
